Problem with mobile device login to admin panel on NSA310
MMK
Hello, when I try to login into administration panel on my NSA310 using any mobile device the NSA web server redirecting me to playzone login page and I can not access administration menu on my device. I don’t have problem with login with desktop. I tried to enter the address to access the admin panel manually like 192.168.0.108/r41773,/adv,/login warp.html but all my mobile devices are redirected to
http://192.168.0.108/r41773,/playzone,/mobile_login.html. Please if anyone has a solution to the problem share it 0
My 'Tweaks' package contains an option to patch the redirect in the backend. But I don't know if it also works for a 310. Depends on the backend.To install Tweaks you first have to install MetaRepository. Scroll down for installation instructions.0
It did not work out. I also tried changing the User Agent string to a mobile browser, but again redirected to playzone mobile0
Does Tweaks offer the tweak? In that case it has detected the patchable script, and should it work.If that is the case, try to clear the cache of your browser. It can have cached the redirect.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
