Can't see files from file browser
amookar
Hi
Over the last few weeks I have had issues trying to see my files on my NAS325. This is set up as RAID with 2 disks as one volume. The data is all intact as I can see it from the zCloud app on my phone. When trying to look via the file browser on the NAS Starter Utility, I see directories but not files. Also tried using Filezilla on the PC, can login to the NAS, but only shows a '\' directory with no directories or files.
I'm using Windows 10 and can't access via File Explorer, but that's a windows issue with the SMB. Which I've tried to work around, but still doesn't work.
I'd like try and get my data backed up to an external drive. Did try this by attaching a portable HDD to the USB on the front and pressing the copy button. Ran for an hour and then the a red LED indicating it failed. When I removed it and attached the external HDD to my laptop, the HDD is in-accessible.
Can you help to try and fix why the files can't be seen. If I could either get the FTP or the copy to the external drive to work, that would be appreciated.
Thanks in advance
Thanks in advance
Best Answers
Your data isn't gone, I think. The data volume /dev/md0 has more than 1TB data on it.As the ssh server doesn't stick, I think you have a damaged settings file, and I advice you to try out a factory reset first. Keep the reset button pressed until it has beeped 3 times. (+/- 15 seconds).After the reboot goto the shares menu and re-enable them.0
I had done a power on reset before, but may have only done it to 2 beeps. Anyways, did this to 3 beeps. Re-enabled the shares and looks good. Can access all the shares even from windows explorer. SSH still doesn't stick, but that is minor.
Thank you very much. Now to spend hours copying the data over to a backup drive :-)
Do you have access to the admin webpage? Can you install the ssh server package, login over ssh, and post the output ofdf0
HI,
Yes can login to admin webpage. SSH package was showing as not enabled. Tried to enable and apply, but when I go back in, it's still not ticked. So when I use Putty to ssh in I get a Network Connection Refused. I can Telnet in and the df command displays the following,Filesystem 1K-blocks Used Available Use% Mounted on/dev/mtdblock8 48896 44256 4640 91% /zyxel/mnt/nand/dev/sda1 497829 490380 7449 99% /zyxel/mnt/sysdisk/dev/loop0 138829 122773 16056 88% /ram_bin/dev/loop0 138829 122773 16056 88% /usr/dev/loop0 138829 122773 16056 88% /lib/security/dev/loop0 138829 122773 16056 88% /lib/modules/dev/ram0 5120 4 5116 0% /tmp/tmpfs/dev/ram0 5120 4 5116 0% /usr/local/etc/dev/ram0 5120 4 5116 0% /usr/local/var/dev/mtdblock4 10240 1496 8744 15% /etc/zyxel/dev/md0 1922352464 1158637860 763714604 60% /i-data/bd068fa7/dev/md0 1922352464 1158637860 763714604 60% /usr/local/zy-pkgs/dev/md0 1922352464 1158637860 763714604 60% /etc/zyxel/zy-pkgs/dev/md0 1922352464 1158637860 763714604 60% /usr/local/apache/htdocs/adv,/pkg/dev/md0 1922352464 1158637860 763714604 60% /usr/local/apache/web_framework/data/cache/dev/mtdblock4 10240 1496 8744 15% /usr/local/apache/web_framework/data/config/dev/md0 1922352464 1158637860 763714604 60% /usr/local/apache/htdocs/adv,/res/imdb_poster0 -
- 588 USG FLEX H Series
- 477 News and Release
