Do FXP transfer on Zyxel NAS 542
Skidrow
Skidrow Posts: 4 image  Freshman Member
Hi
I only get Site-to-site Transfer Failed! when I try to move on the NAS with FTP-software, is there something I can do to fix that?
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    My 'Tweaks' package has an option to enable the FXP capabilities of the FTP server.
    To install Tweaks, first install MetaRepository. Scroll down for installation instructions.
  • Skidrow
    edited September 2020
    Thx but still dont work, think I manage to do all steps in your guide. You write it is a option but cant find that option.
    Downloaded ZYPKG_INFO and MetaRepository_20181001_arm_015.zpkg but them I should not use?
  • Mijzelf
    No, you should use the file web_prefix, as you can read on the MetaRepository page I pointed to.
