VMG1312-B10D Remote management
Kingdavid
Hi
I have Zyxel router VMG1312-B10D firmware V5.13(AAXA.7)C0 . I can't manage it remotely
I of course enable the remote management, I tried Http, Https tried to change the port - nothing !
Very frustrating
Please help
Regards
david
#CPE_Mar_2019
Very frustrating
Please help
Regards
david
#CPE_Mar_2019
Hi Kingdavid,I did some tests, all services (http/https/telent/ping) from wan to device are no problem.You can go to Remote Management > Service control and then check “wan interface used for service” option. The default setting is “Any_WAN”, if you have specific interface for these service, you need configure it to “Multi_WAN” and select to correct interface.0
Hi
thanks for your answer, I tried it but still the same result can”t manage remotely
I do not see also at the “status” screen that this service is open
?0 -
Hi Kingdavid,
The status page will not show this information. May I know your location and who is your service provider?0 -
Hi Kingdavid,
In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.
Hello, I have the same problem as reported above. I am in Finland and the operator is Elisa. I am checking that these configurations are enabled:
I can able to access the router from same network (LAN) using public IP, but not from internet. Are there any additional configuration needed?0 -
From your settings, WAN is not enabled and that is the reason why you can not access it from Internet. Only LAN/WLAN is enabled now.
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
