VMG1312-B10D Remote management
Kingdavid
Kingdavid Posts: 7  Freshman Member
edited March 2019 in Smart Home Product
Hi
I have Zyxel router VMG1312-B10D firmware V5.13(AAXA.7)C0 . I can't manage it remotely
I of course enable the remote management, I tried Http, Https   tried to change the port - nothing !
Very frustrating
Please help
Regards
david
#CPE_Mar_2019
  • YeK
    YeK Posts: 150  Master Member
    Hi Kingdavid,
    I did some tests, all services (http/https/telent/ping) from wan to device are no problem.
    You can go to Remote Management > Service control and then check “wan interface used for service” option. The default setting is “Any_WAN”, if you have specific interface for these service, you need configure it to “Multi_WAN” and select to correct interface.
  • Kingdavid
    Hi
    thanks for your answer, I tried it but still the same result  can”t manage remotely
    I do not see also at the “status” screen that this service is open
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188  Zyxel Employee
    Sixth Anniversary
    Hi Kingdavid,
    The status page will not show this information. May I know your location and who is your service provider?
  • Kingdavid
    Hi
    Thanks, my location is Israel and service provider is Bezeq
    https://www.bezeq.co.il/
    David
  • Zyxel_Support_CPE
    Sixth Anniversary
    Hi Kingdavid,
    In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.
  • Hello, I have the same problem as reported above. I am in Finland and the operator is Elisa. I am checking that these configurations are enabled:
    I can able to access the router from same network (LAN) using public IP, but not from internet. Are there any additional configuration needed?
  • Hummel
    Hummel Posts: 212  Master Member
    From your settings, WAN is not enabled and that is the reason why you can not access it from Internet. Only LAN/WLAN is enabled now.
