Multi X nodes
cjp
How many devices can you have in the mesh? Not clients but the Multy X devices themselves. Also is there an external device?
#MultyX_Jul_2019
#MultyX_Jul_2019
Multy series don't support outdoor environment.
However, there are few options for outdoor mesh AP.
WAC6552D-S, WAC6553D-E.
https://www.zyxel.com/products_services/802-11ac-Dual-Radio-Unified-Pro-Outdoor-Access-Point-WAC6550-Series/overview
Both of them need to use PoE to provide the power, please read all the spec of this product before you purchase it.
WAC6553D-E.
It provides an Embedded heater for harsh weather.
This product will require external antennas for extending the signal range.
https://www.zyxel.com/products_services/2-4-5-GHz-Indoor-Outdoor-Antenna-Antennas-and-Cables/specification
@cjp
You can find the answer in this discussion.
https://homeforum.zyxel.com/discussion/1411/will-multi-handle-6-nodes
You can also add a Multy Mini in Multy X System.
Multy Mini only can expand Multy X WiFi system for additional WiFi coverage. And it must be the last one node in Multy X WiFi System.
https://www.zyxel.com/products_services/Multy-Mini-Dual-Band-WiFi-System-Add-on-Multy-Mini/
Eric, thank you that helps. Is there an outdoor version?
WAC6553D-E.
Boa tarde tudo tranquilo? Estou com um zyxel WAC6553D que retirei da caixa agora a pouco comprado novo junto com outros do mesmo modelo, porém esse eu tenho resposta de pingno ip padrao 192.168.1.2, acesso ele via SSH e via terminal, ja resetei e não consigo acessar ele pelo navegador para configurar. Ja testei em outros computadores e ate mesmo com outros navegadores.0
@Leoni
If you have any questions about WAC6533D, please post your question on Biz Forum.
https://businessforum.zyxel.com/categories/wlan
- 588 USG FLEX H Series
- 477 News and Release
