NSA325 v2 - Error Message "Disk full" - but on HDD´s enough space
Marco78
on my NSA325 v2 i had some Problems... It runs fine for the last 1 1/2 years, but now it have some strange behaviors. They are 2 HDD´s installed (8TB und 2TB). On my 1. HD are 30gb free of 2Tb and on my 2. HD are 200gb free of 8TB, but i cant copy more files on the second HD. The NAS stops copying without any Message..disconnect some Minutes and ist ready again.
No Recycline Bin is activated.
If i log into the User Web Menu. it Popup a Message: Disk is Full...
Why is this happend? I checked both Hdd´s without any errors. I reset the NAS with the Resetbutton, but the Disk Full Message are the same.
Any suggestions?
Thx
Marco
Here some Screenshots
Note: I backuped my 8TB and format it, but same Message:
The message is clear. One of the disks is full.on my 2. HD are 200gb free of 8TB, but i cant copy more files on the second HD.Someone in this forum had the problem that the free space on one of his disks was shown for the other. I can't remember if that was only cosmetical, or if it had serious impact.You could try to pull the first disk, to see if you then can write to the other.
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
