NSA325 v2 - Error Message "Disk full" - but on HDD´s enough space
Marco78
Marco78 Posts: 2 image  Freshman Member
on my NSA325 v2 i had some Problems... It runs fine for the last 1 1/2 years, but now it have some strange behaviors. They are 2 HDD´s installed (8TB und 2TB). On my 1. HD are 30gb free of 2Tb and on my 2. HD are 200gb free of 8TB, but i cant copy more files on the second HD. The NAS stops copying without any Message..disconnect some Minutes and ist ready again.
No Recycline Bin is activated.
If i log into the User Web Menu. it Popup a Message: Disk is Full...
Why is this happend? I checked both Hdd´s without any errors. I reset the NAS with the Resetbutton, but the Disk Full Message are the same.
Any suggestions?
Thx
Marco
  • Marco78
    Here some Screenshots
    Note: I backuped my 8TB and format it, but same Message:
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    The message is clear. One of the disks is full.
    Someone in this forum had the problem that the free space on one of his disks was shown for the other. I can't remember if that was only cosmetical, or if it had serious impact.
    You could try to pull the first disk, to see if you then can write to the other.
