Expanding RAID volume on NAS326 is not working
13»
  • Posts: 2  Freshman Member
    edited August 2020
    I'm trying to follow the steps outlined by Joonas but I'm running into a problem when I try to check the file system on my disk before resizing the partition. I'm getting an error message saying /dev/md2 is in use. Is there any way to tell what process(es) are using it?
    Edit: I did some more investigation. I haven't used LINUX before but when I did "mount | grep /dev/sd" I saw my device was sdc2. I tried "e2fsck -f /dev/sdc2" and got an error message saying the volume was mounted and I ran would severely damage the disk if I proceeded. The drive isn't in use other than what I'm doing to it currently so is this a boilerplate error or am I risking damaging the file system by doing the check?
  • Posts: 2,911  Guru Member
    Joonas list has one fatal flaw. After point 11 'enter :wq' you should run 'poweroff' to initiate the shutdown.
    I am doing "poweroff" after exiting vi. Are there any other processes that might be keeping the drive open?
    lsof | grep /dev/md2
    might tell. I'm not sure if lsof is available.
    What does 'ps' say?
  • Posts: 6  Freshman Member
    Hello, I did the procedure
    # umount /i-data/14fa6d39
    # e2fsck -f /dev/md2
    e2fsck 1.42.12 (29-Aug-2014)
    /dev/md2 is in use.
    e2fsck: Cannot continue, aborting.
     # resize2fs /dev/md2
    resize2fs 1.42.12 (29-Aug-2014)
    resize2fs: Device or resource busy while trying to open /dev/md2
    Couldn't find valid filesystem superblock.
    used  e2fsck -f  and resize2fs command on /dev/vg_5809fa3c/lv_94593ae instead of md2.
    It finally worked fine. Thanks a lot Mijzelf for your explanations
    trying to edit /etc/init.d/rc.shutdown, permission denied. Any comments
    You need to become 'root' first, by executing 'su'.
    Thank you Mijzelf, it worked out.
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
Welcome!
