zyxel vmg1312-b10d not connect to internet after firmware update
Dimitris58
I updated my zyxel vmg1312-b10d to the newest firmware version 5.13(AAXA.10)C0 and after that it cannot connect to internet. My settings are correct and the DSL light stady green but internet is red. My provider said to me that I shouldn't upgrade firmware. Any suggestions?
#SP_Mar_2020
#SP_Mar_2020
You cannot downgrade the firmware. I tried it and the only thing that has changed is the interface.
Hi @Dimitris58
The release notes for 5.13 say that you can downgrade to 5.11 then a manual factory reset is required, see below."External Information:Known issues1. If downgrade FW from V5.13 to V5.1 1, manually factory reset isnecessary2. System may out of memory if upgrade firmware through Wi Fi."
Did your ISP give you new settings?
Kind regards, Tony0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
