VMG1312-B10D upgrade to 5.13
Shoey
I was using a 5.11 version of the firmware of this device and was using dslstats to get the connection data via xdslctl info --stats via telnet.
Since the upgrade i have noticed this has stopped working and when i telnet instead of busybox i am now greeted with ZySh> and a very limited commands.
Is there any way to get dslstats working again so i can use the same xdslctl command?
#CPE_January
#CPE_January
I have the same problem. xdslctl has been removed from the command-line interface and there appears to be no alternative way to obtain stats.
I see nothing in the firmware release notes that warned of this change.0 -
It seems like it was put back in during 5.13 (AAXA.8)b1, see below:
"Modifications in V5.13(AAXA.8)b1Based on V5.13(AAXA.7 C0 to release V5.13(AAXA. 8 b1[Feature Modification]1. Update WWAN 3G package v1.18.2. Support zycli reboot command.3. New factory maintenance mechanism.4. [eits #180200740] Support ROM-D backup.5. [GUI] New GUI 2.0 design.6. [GUI] Add warning message for remote syslog.7. [eits #180100438] Support xdslctl command.8. [eits #180200587] Concurrent bridge and routing."
Kind regards, Tony0
- 435 Beta Program
- 176 Nebula Ideas
- 424 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
