Multy X Placement
tortho
Good day all,
I have a couple of questions regarding the Multy X and believe it is called multi mini.
1.
Is there any pros/cons or restrictions on the placements?
Then thinking of since it has a bottom rubber ring/plate it is designed to stand in a shelf or on a table.
Will there be any issues hanging it on the wall or even placing it upside down in the roof?
2. Any recommendations on an app or similar to do some tests to find best placements in the house?
I have now 6 multy x covering the area over 2,5 floors with massive walls and other obstructions in an L shaped house..
1.
Dear Sir,Ceiling installation and wall installation are fine.If there are lots of obstacles between multy devices, it will affect the signal between Multy devices.There should be no microwave ovens, 3G/4G repeaters nearby, which affect 2.4GHz.When installing the Multy device on Multy app, App will display the signal strength to show if the current location is good enough.You can refer more information on Multy X FAQ > Setup and Configuration FAQs0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
