Routing and QoS
Sir KiKo
Hello
I have a router VMG3925-B10C, I read the documentation for VMG routers and now I came across a chapter where everything is not completely clear.
Which interface is defined as br0?
In the Add new static route setting, there is the "Use gateway address" option; which GW will be used when this option is disabled?
Which interface is used when selecting "Use interface > Default"?
Is it necessary / recommended to turn on RIP; I use VMG router as a domestic border router for connect to internet.
Is it good to enable QoS and if so, which Upstream Traffic Priority is the recommended one: Ethernet Priority/IP Precedence/Packet Lenght? We use only music (Spotify), video streams and standard internet browsing.
Best regards,
Martin
Best regards,
Martin
Hello @Sir KiKo Martin,I hope that you are well and have made progress.I think that in an ordinary domestic situation where the VMG3925-B10C is connected directly to the local telephine network then you do not need to add a static route, because the VMG3925-B10C will be the default gateway for all of the devices on your home (local area) network.The VMG3925-B10C will then use your Internet Service Provider as its default gateway.I think that you probably also do not need to use Quality of Service (QoS) controls in a domestic situation, unless something is taking all of your network capacity.I hope that this is helpful.Merry Christmas and Happy New Year 2021.Tony
For my upstream traffic priority, I have to choose between packet length, ethernet priority and IP precedence.
Which is the best for online gaming?
Depends on your online game.
If it uses short packets in real-time, then packet length will be good.
But it depends...
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
