NAS 542 BootLoop after debian kernel upgrade and fdisk
Georg
Hello all,
after successfully installing the Debian kernel, I noticed that there was not enough space on the SD card for an update of debian.
Therefore I tried to expand the partion with fdisk and I destroyed something - this was a very big mistake!
Now the NAS is in a boot loop and access is no longer possible.
Is there a solution for this or can I the NAS throw it away?
Best regards
Georg
Best regards
Georg
Best Answers
An SD card is not really designed to run an OS from. Due to a lot of micro writes (logfiles) the memory wears out. When you want to exchange the card, you can google for SD card recommendations for the Raspberry Pi, which has the same problem.
Hi Mijzelf,first happy new year!
And thank you for your help. Yes, this was the problem! I had two problems with the SD card, first the boot sector was damaged and the SD card itself had errors.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
