Zyxel Armor G5 - NBG7815
Scorpione
Scorpione Posts: 34 image  Freshman Member
Hi, there are a lot of corrections to be made on this young model: 1. Translation, in my situation to italian (es. clear >> pulisci, and not chiaro: light) and other words 2. Cloud account doesn't recognize the mac adress and serial of router, manually too 3. The link aggregation function today is a must have 4. Is important an auto reboot time day by day and more settings to add
«134
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Dear Sir,
    Thanks for your opinion, we’ll evaluate your suggestions of the enhancement on Armor G5
    For the second request, do you mean the device is not shown on the Pcloud?
    And you would like to see the device on the Pcloud?
    Best regards,
    Jerry
  • Asgatlat
    Asgatlat Posts: 4 image  Freshman Member
    SurveyFeedback-2022-Mar
    hi,
    just to say that french translation is also very bad on the G1 model
  • Scorpione
    For cloud: i do the login with Apple because have two factor security and it's ok, if i try to log for a vpn server the apple account is not visible and i must log with mail (maybe another account auto created but useful for app remote on ios)
  • gnivat
    gnivat Posts: 15 image  Freshman Member
    Agree with Scorpione. I can add that :
    - I am not able to register the product on Zyxel websites.
    - There is no possibility to backup the router configuration.
    - I have to use it as an AP. After 24h as a Router, it become unstable.
    - The landing page with the kind of "Widget" sometime just freeze and it is not possible to access the configuration.
  • Scorpione
    Try to reset the zywall and if you have other problems with registration go inside with local login, if you can
    For backup config go in tilt / have you the circle to wait?
    The automatic firmware don't update? Actually is at 5c
    In my situation i'm login to ppoe if can be useful
  • gnivat
    Thank's Scorpione for your suggestions.
    Today, I can login into my Armor G5 router with the local account but the widgets of the landing page don't load and the page is stuck.
    I would prefer not to reset the router as I already spent some time on it !
    How do you backup/restore a configuration ? what is tilt ?
  • Scorpione
    edited January 2021
    tilt: term as the flipper :)
    the restore/backup is a function that must to be on "maintenance" but Zyxel i hope it fits
  • Zyxel_Jerry
    Dear @gnivat,
    Could you share your network topology?
    What is the firmware version you're currently using?
    Does the landing page still not load and still stuck on the page?
    You can try to use incognito to access the Web GUI.
    We do not have an option to backup configuration on Web GUI.
    We'll evaluate the feature.
    Best regards,
    Jerry
  • gnivat
    Hello Jerry,
    Here is the version of my FirmwareV1.00(ABSK.5)C0
    I have to use my Armor G5 has a AP because as a router the softwware is really unstable.
    The landing page is stuck sometime, today it is not. Good thing as I have to add a MAC Address to the Wifi MAC Filter
    I will try with incognito mode next time it is frozen
    Regarding the backup/restaure, I don't think this is an option for you !!
    It is written in the documentation !! P 13
    And this is the most basic feature of any router !!
    Thanky for your help.
    Guillaume
  • Zyxel_Jerry
    Dear Guillaume,
    Thanks for your suggestion,
    We'll adjust the documentation.
    Best regards,
    Jerry
