[NEBULA] Multiple WAN configuration
Hello @Januzki
Apologies for the late reply!
The NSG currently only supports an active-active type failover.
Wherein the NSG uses both WAN interfaces to distribute traffic to the Internet when both WAN interfaces are up, while routing across a single interface should any of the other WAN interface goes down.
But to answer your question, I would like to invite you to post it in our Idea Section or let us do so. We will evaluate the feasibility and then get back to you.
Best regards,
Barney Gregorio
This is a desperately needed feature since policy routing is also unavaiable.0
But isn't an active-passive type fail-over solution obsolete if you already have an active-active type fail-over?
It even looks like NSG has the option to set rate limits per WAN port.
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 663 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 498 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
