USG-50 Limiting our bandwidth, why?
Hello, a few days ago we changed our ISP and currently paying for 300mb. When testing our internet speed behind the firewall we get speed of 150mb, when I bypass the firewall I get speeds up to 300mb. What would be the optimal settings I need to change on the firewall to take advantage and use the bandwidth we are paying for.
Hi @Eduardo
Welcome to Zyxel community!
Your question seems to be related to USG products.
I will move your discussion to USG page and you can keep discussion on USG page.
Thanks!0 -
Hi @Eduardo,
As we checked, the throughput is around 225/Mbps on lab testing. There are some factors that influence the throughput testing.
e.g. USG configuration, testing PC performance, anti-virus, os environment and so on.
Could you share more information how you do the performance test? speed test server? Iperf? how many sessions you run for throughput test?
Hi Thanks for your prompt reply,
This is what im using to run the internet speed test http://www.speedtest.net/. Like I mentioned when I bypass the USG I get close to the speed we should have, when I connect behind the USG the bandwidth slows down to almost half. Im using the same pc to test this. Im not an expert on networking and some settings on the usg seem a little confusing. Therefore I reach out to this forum to see if someone can suggest me where I should look on the USG or guidance of the proper settings. Our network is simple, there's no port forwarding, there's no bandwidth limitation to any user, there's no filtering. Hope this helps0 -
Hi @Eduardo,
Did you enable BWM(Bandwidth management), Anti-Virus, IDP, or Content filter ? Can you disable these service and try it again.
How to check those service on by CLI:
Router# show firewall status
Router# show bwm activation
Router# show anti-virus activation
Router# show idp signature activation
Router# show content-filter settings
I have the exact same problem on a 260mb connection, tested directly connected workstation, then with a Cisco 2811 and a Asus RT-88AC I would get 260mb, but with the USG-40 I get barely 85mb with services on, and with the services desabled I get 150mb...0
Please any input on how to configure your device to reach at least 200mb+ would be appreciated, we purchased the equipment and according to your website it states up to 400mbps without any services.0
Is there an upgrade path, do we need to purchase another model?0
With everything on I get 85mb/s, with everything off and double checked in CLI using Eduardo's suggested commands I get 180mb/s at the most, still short of 260mb/s which I get with a 2811, workstation or a cheapo Asus router.Is there anything I can do other than returning the device?1
The USG 40 maybe listed as 400Mb but under given test conditions with TCP and without Anti-Virus, IDP, or Content filter you should get about 200Mb
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
