Can't see SSID with nebula
PeterUK
edited April 2021 in Nebula
I'm trying to setup a NWA1123-AC-HD on firmware 6.10(ABIN.8) with nebula but even the open SSID test in nebula does not show up!
When a login to the AP I get:
Ethernet: This access point is directly connected to a local network. IP Address: 192.168.252.1
Internet: This access point is connected to the Internet. Nebula Connectivity
Status: This access point is successfully connected to the Nebula.
Nebula Control Center
Activation Status: This access point has been registered to the Nebula.
Use Proxy to Access
NCC:no
What I'm I doing wrong? Tried a reset too
Thanks for any help
In standalone mode for now
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @PeterUK
    We might need to wait some more time for the NWA1123-AC-HD to go online because AP will apply the Nebual default configuration when it connects to NCC the first moment and waits to receive the configurations from NCC. This will take around 10-20 minutes. If the AP goes online, but you still cannot see the correct SSID, can you let the AP back to NCC online first? And please provide your org/site name and enable the ZYXEL support for me. I will help to check the AP status.
    Joslyn.
    Ok I did it wrong and got it working what I did wrong was make the site then added the AP to Inventory and not linking it to the a site.
Nebula Tips & Tricks
