Armor G1 - NBG6818
KLS
KLS Posts: 2
image  Freshman Member
What is the password for for the exported log file "log.tar" ?
It is not the login password for the router.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406
    image  Zyxel Employee
    edited January 2021
    Dear @ KLS,
    The log file is for Zyxel support purpose and the credential can’t be released.
    Best regards,
    Jerry
  • KLS
    KLS Posts: 2
    Thanks Jerry
    How do I contact technical support - I have filled out the form on the web page twice.
    When subitting form the webpage the page tels that you will recieve an email - but nothing happens.
  • Zyxel_Jerry
    edited January 2021
    Dear @ KLS
    Here are the pages you could connect to local support
    https://support.zyxel.eu/hc/en-us
    Select the language on the upper right corner
    You can connect to your local support for further assistance.
    Best regards,
    Jerry
