Wifi Name and password
Brecksderby
Hi I have a virgin hub that is set up with its 2.4ghz ssid and 5ghz ssid since setting up my multy x i now have 4 wifi sign ons 2 with the multy x i have set up and 2 with the virgin hub. is there any way to integrate so i only have 2 sign ons 1 for 2.4ghxz and one for 5ghz?
Dear @Brecksderby
Multy device has its own Multy wifi network, Multy cannot integrate with other wifi.
If you would like to separate wifi SSID on 2.4G and 5G of Multy device
Multy X allows to use different WiFi SSIDs for 2.4GHz and 5GHz in the network.Go to homepages and click the third icon from left to right,
It will go to WiFi Settings pages > Click “Edit”
After change the SSID into different name, click “Save” button on upper right corner.
Best regards,
Jerry0
Dear @Brecksderby
Best regards,
Jerry0 -
thank you have changed my virgin hub to modem only and now have just the multy WiFi thanks for your help0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
