Zyxel Armor G5 - NBG7815
Scorpione
in Home Router
Hi, there are a lot of corrections to be made on this young model:
1. Translation, in my situation to italian (es. clear >> pulisci, and not chiaro: light) and other words
2. Cloud account doesn't recognize the mac adress and serial of router, manually too
3. The link aggregation function today is a must have
4. Is important an auto reboot time day by day and more settings to add
Dear Sir,
Thanks for your opinion, we’ll evaluate your suggestions of the enhancement on Armor G5
For the second request, do you mean the device is not shown on the Pcloud?
And you would like to see the device on the Pcloud?
Best regards,
Jerry
hi,
just to say that french translation is also very bad on the G1 model0 -
For cloud: i do the login with Apple because have two factor security and it's ok, if i try to log for a vpn server the apple account is not visible and i must log with mail (maybe another account auto created but useful for app remote on ios)
Agree with Scorpione. I can add that :- I am not able to register the product on Zyxel websites.- There is no possibility to backup the router configuration.- I have to use it as an AP. After 24h as a Router, it become unstable.- The landing page with the kind of "Widget" sometime just freeze and it is not possible to access the configuration.0
gnivat said:Agree with Scorpione. I can add that :- I am not able to register the product on Zyxel websites.- There is no possibility to backup the router configuration.- I have to use it as an AP. After 24h as a Router, it become unstable.- The landing page with the kind of "Widget" sometime just freeze and it is not possible to access the configuration.Try to reset the zywall and if you have other problems with registration go inside with local login, if you canFor backup config go in tilt / have you the circle to wait?The automatic firmware don't update? Actually is at 5cIn my situation i'm login to ppoe if can be useful1
Thank's Scorpione for your suggestions.Today, I can login into my Armor G5 router with the local account but the widgets of the landing page don't load and the page is stuck.I would prefer not to reset the router as I already spent some time on it !How do you backup/restore a configuration ? what is tilt ?0
tilt: term as the flipper
the restore/backup is a function that must to be on "maintenance" but Zyxel i hope it fits
Dear @gnivat,
Could you share your network topology?
What is the firmware version you're currently using?
Does the landing page still not load and still stuck on the page?
You can try to use incognito to access the Web GUI.
We do not have an option to backup configuration on Web GUI.
We'll evaluate the feature.
Best regards,
Jerry
Hello Jerry,Here is the version of my FirmwareV1.00(ABSK.5)C0I have to use my Armor G5 has a AP because as a router the softwware is really unstable.The landing page is stuck sometime, today it is not. Good thing as I have to add a MAC Address to the Wifi MAC FilterI will try with incognito mode next time it is frozenRegarding the backup/restaure, I don't think this is an option for you !!It is written in the documentation !! P 13
And this is the most basic feature of any router !!Thanky for your help.Guillaume
Dear Guillaume,
Thanks for your suggestion,
We'll adjust the documentation.
Best regards,
Jerry
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
