ZYXEL Armor G5
The firmware has flown , flashing blue - reboots every minute . How to restore firmware . By LAN 10G connects for 1 minute
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 855
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 50 Answers 500 Comments
    edited January 2021
    Dear @Konstanta
    What is your network topology? Could you provide it to us?
    How do you install your Armor G5, using web GUI or using the app?
    If the 10G is not connected to the device will the symptom still occur?
    Have you ever tried to reset the device?
    After reset to default, does the symptoms still exists?
    Best regards,
    Jerry
  • 1 cable from provider and pc
    2 first app Android , after web GUI
    3 Yes
    4-5 does not reaction to reset.
  • Scorpione
    Scorpione Posts: 33
    Try without 10g using 1 yellow gbit
  • Я все перепробовал . Worked in the evening - almost no load , then lit up red - flashes blue after restarting
  • tried everything , from LAN and without
  • Zyxel_Jerry
    Dear @Konstanta,
    May I know what do you mean  "Worked in the evening - almost no load , then lit up red - flashes blue after restarting"?
    What model of the transceiver are you using?
    What is the topology at the time?
    When doing the reset, could the Armor G5 get an orange LED after resetting it?
    After reset, does the device still keep rebooting?
    If the device works fine after reset, are you able to access the web gui?
    Best regards,
    Jerry
  • Armor G5 get not an orange LED after resetting it
    the device keep rebooting after reset.
    "reset" button doesn't affect on work.
    https://yadi.sk/i/ZQNTHOZa4YLAsg
  • The power supply unit is working, it outputs 19 volts
