WDS problem and workaround.
PeterUK
PeterUK Posts: 4,267 image  Guru Member
edited May 2024 in Wireless
Hi
So I have a WAX510D with 6.10(ABTF.8)C0 it controlled by USG60W and Radio 2 as AP root and I have a NWA1123-AC HD with 6.10(ABIN.8)C0 with Radio 2 as Repeater got it all working until I rebooted the NWA1123-AC HD and it stopped working as in I connect to NWA1123-AC HD and get no internet.
My workaround is have NWA1123-AC HD Repeater powered up first then reboot WAX510D AP root.
«134
  • Zyxel_Freda
    Zyxel_Freda Posts: 397 image  Zyxel Employee
    25 Answers First Comment Friend Collector Third Anniversary
    Hi @PeterUK,
    When the repeater AP rebooted but the client could not go to the Internet, was the mesh connection built up?
    edited January 2021
    From what I can tell its not allowing the mesh connection built up when the repeater AP is rebooted here is the log from USG60W for WAX510D
    2021-01-29 10:22:26
    info wlan-station-info
    STA Disassociation(34:DIASSSOC_LOW_ACK) by STA Timeout. MAC:BA:E4:26:XX:XX:XX AP:AP-BCCF4FXXXXXX, interface:wlan-2-9, SSID:Zyxel_WDS, Tx/Rx:1397398/4514797 Bytes, session time:5H:25M:55S
    2021-01-29 10:23:53
    STA Association. MAC:BA:E4:26:XX:XX:XX, AP:AP-BCCF4FXXXXXX, SSID:Zyxel_WDS
    Only when I reboot the WAX510D with the NWA1123-AC HD fully booted does the mesh connection built up.
    edited January 2021
    I'm also finding that the link between the AP's goes down after many hours of being up and needing to reboot the WAX510D for the NWA1123-AC HD  Repeater to work.
  • Zyxel_Freda
    Hi @PeterUK,
    Thanks for your information. The log "STA Disassociation(34:DIASSSOC_LOW_ACK)" means that the station didn't reply AP for some time, so the AP disassociate it. May I know the distance between the root and repeater? Because we'd like to check more detail information, would you help to collect the diagnostic info to us when the issue is occurring. We'll check detail logs about building the mesh. You may collect the diagnostic in MAINTENANCE> Diagnostics> Diagnostics> AP. And, the collected files will be able to download in MAINTENANCE> Diagnostics> Diagnostics> Files.
    Please PM me the diagnostic info after you get it.
    Thanks.
    I PM you the diagnostic info for WAX510D when the link goes down to the NWA1123-AC HD.
    The distance between the root and repeater is only 6 meters.
  • Zyxel_Freda
    Hi @PeterUK,
    Did you send the diagnostic info to me because I didn't get any information in my inbox?
    I had to reboot both AP so when it happens again I send you the diagnostic info.
  • Zyxel_Freda
    Hi @PeterUK
    Got it, and thanks. Please let me know if you PM me the diagnostic, and I'll check it in my inbox.
    So for some reason the 2nd bug is not happening so I PM you the 1st bug when rebooting only the  Repeater wait 10mins and the get no internet from it until I reboot the AP root.
    2nd bug happened that the link between the AP's goes down after many hours of being up I send you a PM
