NAS 540 - Admin share deleted
Celestino
Hi, I deleted the admin folder by mistake and now it appears with "lost" status under the Shared Folders of the Control Panel. Is it possible to recover or delete it, so a new share can be created?
Thank you in advance for your help.
Thanks a lot!0
AFAIK it's not possible to remove the admin share using the firmware capabilities. You can delete the directory using shell access, but that doesn't remove the share (share as in: configuration line in in smb.conf).So you can put the directory back (mkdir /i-data/sysvol/admin), or live with the 'lost' status.0
Thanks a lot!0
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
