Hard disk Compatibility for NSA221
DavidT2020
Recently, my NSA221, yes NSA221! showed a red light for my disk 1. I checked the manual and it suggests that my harddrive is degraded. Well, my NSA is still nice and good and I don't want to dump a workable (still) NSA and buy a new one. Thus, I would like to buy a new harddisk to replace the degraded one. It seems that the SATA-3 HD can downward compatible to SATA1 and 2. I would wonder whether a SATA-3 harddisc, Ironwolf 1TB, can be used on my NSA?
Thanks in advance.
Thanks in advance.
It should. SATA is SATA. I don't know if the box supports GPT, so a disk >2TB could be a problem.
I will have a try and see! Thank you so much!0
- 244 Nebula Ideas
- 6.9K Security
- 800 USG FLEX H Series
- 392 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 328 Service & License
- 532 News and Release
- 104 Security Advisories
- 5.5K FAQ
- 91 About Community
- 124 Security Highlight
