Dual wan failover not working
Hi all,
I configured our USG40-W to be dual wan using the OPT port. I configured a trunk to spillover and set WAN1 as active, WAN2 as passive. As best I could tell all was working fine. I then configured WAN1 (advanced settings) connectivity check ICMP, 5 sec period, 1 sec timeout, 3 fail tolerance, checking address 8.8.8.8
However, when I disconnect the fiber into the modem on WAN1 no network is available. Even after about 2 minutes.
If I look at WAN1 and WAN2 they both show connected normally. When I unplugged fiber, WAN1 showed disconnected and WAN2 showed connected. However, we could not access any external sites only internal ones.
Sorry I am pretty new at this stuff. Any help would be appreciated.
Thanks in advance!
Make two rule in network > routing
1st rule top
Incoming = Interface
member = lan1
next hop
type = Interface
interface = wan1
show advance and check enable connectivity check with a IP
2nd rule below
member = lan1
next hop
type = Interface
interface = wan2
- 441 Beta Program
- 293 Service & License
