Multy Mini in star topology on ethernet backhaul
Robert22
Hi. Can I use two Multy X with one Multy Mini in a star topology on ethernet backhaul? The first Multy X will be the main Multy and the second Multy X and the Multy Mini will be connected to the first main Multy X to its LAN ports.
Hi @Robert22,
You can refer to the below KB article to set up the Ethernet backhaul settings.
https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=017839&lang=EN
Best regards,
Jerry0 -
Thank you, but there is no answer for my question in the article. Can I put the ethernet backhaul to the LAN ports in the main Multy X for a second Multy X and for one Multy Mini? Will it work?Zyxel_Jerry said:Hi @Robert22,
Best regards,
Jerry0 -
Hi Robert,
please check this for all combinations:
https://support.zyxel.eu/hc/en-us/articles/360013835139-How-to-build-a-Ethernet-backhaul-on-Multy-X-Multy-Plus-and-Multy-mini-It can work in the end if you follow the design and limitations of Multy Mini like:
1) Multy mini requires only Multy X as a Root.2) Multy mini cannot work with Multy Plus or Multy U.3) Multy mini has to be the last node.
Kind Regards,
Tobias0
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
