AP Zyxel NWA1123-ACv2 with Zyxel USG110 - Guest Network not work
Nebula_BC
Nebula_BC Posts: 1 image  Freshman Member
edited April 2021 in Nebula
I have a primary SSID on VLAN 1 (default) and work correctly for internal network.
I tried to enable "guest network" on secondary SSID for guests, but it didn't work on internet
I also tried to disable "guest network" and setting a different VLAN ID (for example VLAN10)
on secondary SSID with the same settings of my FW Zyxel USG110 but it didn't work.
On secondary SSID I couldn't access on internet.
I need an help.
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @Nebula_BC
    According to the design of Guest network, it will enable L2 isolation and add the gateway MAC into whitelist automatically. If you have the DHCP server or DNS server in the same subnet, they also are needed to add into the L2 isolation whitelist.
    Access point > Configure > Authentication > Layer 2 isolation.
    If it still does not help, please provide your org/site name and enable Zyxel support for me(Help > support request).
    Joslyn
Nebula Tips & Tricks
