OpenVPN support for USG router ?
  • Mario
    Mario Posts: 104  Ally Member
    First Anniversary 10 Comments Friend Collector Zyxel Certified Network Engineer Level 1 - Security
    Secuextender is sometimesa useable replacement, but it has no IOS / Android support.
    But I don't belive, this will ever happen. :s
  • dpipro
    dpipro Posts: 64  ZCNE Certified
    First Anniversary ZCNE Switch Level 1 Certification - 2020 ZCNE Nebula Level 1 Certification - 2020 ZCNE Security Level 1 Certification - 2019
    Hi @Mario
    for iOS / Android you must use L2TP over IPSec. It works great!
    Best regards
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,062  Zyxel Employee
    First Anniversary 10 Comments Friend Collector First Answer
    edited February 2021
    Hi @chr,
    This issue has been fixed.
    We'll help you to upgrade the firmware.
    Could you provide us the remote access to your Armor G5 device?
    Below are the step to provide a remote access on Armor G5
    Please follow the below steps to provide us the remote access to the device.
    1.      If your Wan are using public IP address, please go to armor G5 web gui > Settings > System>
             enable Access Interface WAN & LAN and enable Remote Assistant
    2.      Please provide us the account and password of your device and also the wan interface port number.
    3.      Please provide the above information using a private message to us.
    Best regards,
    Jerry
  • Lemonick
    We in the small country of SLOVAKIA are also waiting for the support of OpenVPN in Zywall devices.
    We therefore stopped selling them.
    When will the implementation take place ???
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,366  Zyxel Employee
    Support OpenVPN already exist in our roadmap.
    But currently still without correct schedule for it.
  • lbocquet
    OpenVPN is very important!
    And it will be nice to have Wireguard support too:
    - https://community.zyxel.com/en/discussion/1992/wireguard
  • Mario
    @Zyxel_Stanley wow, great news! I hope we see it soon, I'm waiting since 2010 for this function :#
  • Westbike01
    will be OpenVPN finally supported by USG20-VPN ? In witch FW ?
    Excited to test it !
    Otherwise please explain us how we can install and configure the SSL client on Linux platform to connect with USG20.
    BTW L2TP is not a solution for us.
  • mMontana
    mMontana Posts: 1,300  Guru Member
    Why zyxel should stop making money on VPN Clients (IPSec and SSL) allowing OpenVPN to be used instead of their payed license?
  • TeleCrew
    TeleCrew Posts: 2  Freshman Member
    First Anniversary Friend Collector First Comment
    @Zyxel_Stanley any time map about open VPN ??? we need it.
Security Highlight
