ATP500 reboots at 00:00
it happened twice, the ATP reboots at 00:00. I've checked the watchdog log that reports Reason: <Continue> Fatal Error Cause System Reboot
Log length: 21922/32728
Log time: 2021-02-25 00:00:18
Anyone had this issue?
F/W Rev 4.60(ABFU.0)
Thank you
Thank you
Best regards
Hi @dpiproWe suggest you upgrade to V4.62WK02.You can refer to this link to download it.BTW, when you upgrade to V4.62WK02 successfully you can collect the console log of your ATP500.Please refer to this link:If your ATP500 reboot again please provide this log to us via private message for further investigation.Thanks.0
Hi @Mario
Hi @Zyxel_Jeff
Thank you for your answers.
Yes, I have the daily report enable, it is configured to be send at 0:00, I will disable it. It could be the same issue as yoursBest regards0
- 588 USG FLEX H Series
- 477 News and Release
ZCNE Certified
