LTE3302 Firmware upgrade failure
Robgdy
I tried to update the firmware, downloaded the latest version (LTE3302-M432_V1.00(ABKQ.1)C0.zip), check checksum, unzip, select *.bin file in WebGUI, click "Upload" but unfortunately it failed. Onthe back of my device I found "LTE3302-M432". I tried reset to factory settings (from WebGUI), and push switch "RESET" on the back device but the same result every time as in the picture below
How can I check actualy instaled firmware version?
Are there other methods of uploading the firmware?
Best regards, Robert
Hi Robert,
which firmware version is currently on your device installed?
Kind Regards,
Tobias0 -
What should I do if my router does not work after a failed firmware upgrade? The power light is just continually blinking.https://support.zyxel.eu/hc/en-us/articles/360007482819-Firmware-to-re-flash-LTE3302-M432 https://domyessay.onl
@Robgdy,
Could you please provide your LTE3302's firmware version?
@cynthiamiller,
Could you please describe whether the power LED's behavior, does it blink like once every half second (fast) or does it blink once every 2 second (slowly)?
Also, does the other LEDs also blink?
Are you able to access the router's user interface through your LAN IP address (e.g. 192.168.1.1 by default)?0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
