Can I update my NSA320?
JimFord
Firmware updates ended in 2016 (.V4.70(AFO.3)). Are there any updates that I can download and install manually, please?
Jim
Hi,I think there is no new firmware of the device NSA320.Is there some problem you met?Maybe you can consider to buy a new NAS.0
Hi Hill,I have the same box (NSA320) and the problem is that Windows 10 has now switched to SMB2 from SMB1 for security reasons and Windows 10 will not let a user map a drive using SMB1 protocol. I was wondering if the NSA-320s firmware would work as an update as it is available from Zyxel but I don't want to try it unless I know I won't lose my data.John0
I found the solution to my problem here.0
Buying a new NAS isn't really a viable solution, also I really don't want to go through the 'faff' of installing FreeNAS or OpenNAS and risk losing 2TB of media files.0
JimFord said:I really don't want to <snip> risk losing 2TB of media files.
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
