Send dump file for modem VMG1312-B10B or B10A
MOHAMMADSAEID
Hi. I have a Zyxel modem model VMG1312-B10B. When I tried to update the
firmware, unfortunately, the modem did not boot anymore and its power
light blinked. I ask you to help me and send me the modem dump file to
program it, because I did not find anything when I searched. Thank you.
Hello @MOHAMMADSAEIDI don't work for Zyxel, but what colour did the Power LED flash when it blinked.For the VMG1312-B10A, a blinking Green Power LED is fine for a period of time, see section 1.5 of the user guide at ftp://ftp.zyxel.com/VMG1312-B10A/user_guide/VMG1312-B10A_1.00.pdfFor the VMG1312-B10D, a blinking Green Power LED is also ok, see section 1.4.1 of ftp://ftp.zyxel.com/VMG1312-B10D/user_guide/VMG1312-B10D_V5.13_5.50.pdfI have a VMG1312-B10D myself, and had been able to do a firmware upgrade, but it did not go well first time.I will share my post to that here soon.If you have a copy of the configuration of your router, then it might be worth you doing a factory reset.I hope that this is helpful.Kind regards,Tony
Hello @MOHAMMADSAEIDHere is how I managed to upgrade the firmware on my VMG1312-B10D, see https://community.zyxel.com/en/discussion/comment/27576#Comment_27576I hope that this is helpful.Kind regards,Tony0
- 432 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 387 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
