LTE firmware for SBG3600
Teme
Teme Posts: 2  Freshman Member
First Anniversary
edited April 2021 in Security
LTE performance is really poor with current LTE module firmware, but found recommendation to upgrade LTE firmware to get improved 4G performance, but can't find new firmware anywhere
Current Firmware Version: ALT3100_04_05_06_10_B8_LO
Zyxel site offer only system firmware and it doesn't upgrade LTE firmware.
Where I can download latest LTE firmware?
«13456720
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,537  Zyxel Employee
    Hi @Teme,
    I will send you the latest  LTE module firmware via private message.
  • Peppino
    Peppino Posts: 159  Master Member
    First Comment Friend Collector Seventh Anniversary
    Hi Cooldia,
    Can you please share that firmware with me?
  • Zyxel_Cooldia
    edited May 2018
    Hi @Peppino,
    I sent you the firmware via private message, please have a check.
  • ias
    ias Posts: 1  Freshman Member
    Hi Cooldia,
    same problem here, could you please share that firmware also with me?
    Thanks!
  • Zyxel_Cooldia
    Hi @ias,
  • Pascal
    Pascal Posts: 8  Freshman Member
    Hi Cooldia,
    I have the same problem with the LTE firmware. With the recent upgrade of the router firmware (V1.00(AAKO.8)), the LTE module do not function anymore ... If possible, can you please send me the last LTE firmware ?
    Best regards,
    Pascal
  • Max78
    Max78 Posts: 1  Freshman Member
    First Comment Sixth Anniversary
    edited May 2018
    We do have the same problem with the latest V1.00(AAKO.8) update.
    LTE module is down and was working fine before this update.
    Can you please send us an updated LTE firmware ?
    Thanks.
  • Zyxel_Cooldia
    Hi @Pascal, @Max78,
    Firmware provided via private message, please have a check.
  • systemchecker
    systemchecker Posts: 1  Freshman Member
    Hello, I would like to get the same update file of LTE module. Thank you!
  • Mikko
    Mikko Posts: 2  Freshman Member
    Can you please send the firmware for me as well, thank you!
