nsa320 won't setup
nonobaddog
I am trying to setup an nsa320 on Windows 10 Pro 64 and the starter utility fails to complete installation. I can ping the nsa320 but that is all. Is there a way to get this working?
Try disabling the firewall. And, if you are using wifi, try a cable.
I am not using wifi, it is wired right to the router.I had the firewall configured to notify me of any blocks and it did not send any notifications. So I turned off the firewall completely and that didn't help either.I think the starter utility failed to complete installation of something that it needs.I turned on SBA and that didn't help either.0
Actually you don't need the starter utility. Have a look in your router's webinterface to see which IP address your NAS has got. Or do a portscan in your LAN. Then enter http://<ip-of-nas>/ in your browser. You can do everything in the webinterface.
This could be getting somewhere. I got the NAS IP address but when I try to browse there it says "unable to connect".I find the Windows 10 security settings to be very confusing. Maybe the NAS is shut out somehow and I don't know how to check that.0
The NAS shows up in the router(with a static IP) for a while when I first log in but then it disappears.
A static IP? Is it in your network range?BTW, it might be a good idea to perform a factory reset on the 320. Press the reset button on the back (while the box is up), and keep it pressed until it has beeped 3 times. (Around 25 seconds)0
Yes, the address is static 192.168.1.5 which should be in range, my router is still the default 192.168.1.1, but I will see about fixing the static part and making it DHCP.I did reset the 320 once already but I will try that again.I'll root around trying to see if the NAS is blocked somewhere but I'm kind of flying blind in that area.0
Yes, it beeped appropriately just like the destructions said it would.I pushed and held the reset button, it beeped, held it some more, it beeped, held it for 5 seconds more and then let up and it beeped three times.This is supposed to reset everything, which I believe it did.0
I think I found the answer to this problem here.
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
