LTE7490-M904 SIM Compatibility
zyxymirc
Hi!
Today have ordered a Zyxel LTE7490 Outdoor CPE for replacing previous 4G Antenna, in the Amazon review and answers seems that the CPE is not compatible with italian cellular operator TIM and only with specific firmware works, can you confirm this or was solved with latest firmware?
Thank You in advantage!
The 7490 with latest firmware is compatible with Italian Operator TIM!2
Hello @zyxymircLooking in the firmware release notes at ftp://ftp.zyxel.com/LTE7490-M904/firmware/ and the release notes for the V1.00(ABQY.2)C0 firmware released in September 2020 posted February 2021, there are some SIM fixes mentioned but not the TIM network specifically.Do you know what firmware your device has in it?I hope that this is helpful.KInd regards,Tony0
Thanks!
The unit is expected to arrive Friday and i will be able to test it!
I hope it works out of the box....0 -
- 243 Nebula Ideas
- 6.8K Security
- 781 USG FLEX H Series
- 387 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 324 Service & License
- 527 News and Release
- 101 Security Advisories
- 5.3K FAQ
- 91 About Community
- 121 Security Highlight
