Does WAX510D support 40MHz on 2.4G?
PeterUK
PeterUK Posts: 4,446 image  Guru Member
edited May 2024 in Wireless
I set my USG60W as the controller for WAX510D and set the 2.4G to 20/40MHz but when I view WiFi from more phone I don't see it show that its running in 40MHz? I see my NWA1123-AC-HD run on 40MHz.
Not too big of a deal if it only supports 20MHz just thought I check.
Best Answers
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @PeterUK
    Yes, the behavior in your test after reboot is correct but has to become 20MHz after 20/40MHz applied. We’ll fix the problem in the future version.
    If your expectation of the AP is to use 40MHz to provide services at 2.4G, you can use the command to disable-coexistence after configure channel width to 40MHz.
    Router# configure terminal
    Router(config)# wlan-radio-profile default
    Router(config-wlan-radio default)# dot11n-disable-coexistence
    dev.wifi1.dcs_manual_ch = 1 0
    Setup 2.4G 11AX HE40 channel 6
    dbctl> DB Success!
    dbctl> DB Success!
    dbctl> DB Success!
    dbctl> DB Success!
    Reload DCS Configuration file
    Router(config-wlan-radio default)# exit
    Router(config)# write
    Please noted that in the normal environment, there are a lot of frequency using radio 2.4GHz and causing the interference so a single 20MHz channel will be more stable to use in radio 2.4GHz. Also for legacy client can connect to 2.4GHz SSID without compatible problem.
    Regards,
    Bella
  • Zyxel_Bella
    Hi @PeterUK
    The commands are in the post on April 27 for you to apply on AP by ssh into AP directly.
    After commands take effect, AP can keep service in channel width 40MHz of radio 2.4GHz even your environment has legacy device.
    Regards,
    Bella
«13
  • Zyxel_Bella
    Hi @PeterUK
    Both WAX510D and NWA1123-AC-HD supports 40MHz on 2.4G.
    Select the channel width 20/40MHz means AP will choose bandwidth 20 or 40MHz to provide wireless service.
    The AP adjusts the bandwidth to 20MHz if the AP has detected stations is compatible with 40MHz or other SSID uses 20MHz to broadcast in the environment.
    So you can see WAX510D and NWA1123-AC-HD services in different bandwidth.
    Hope you find this information helpful. Thank you.
    Regards,
    Bella
    edited March 2021
    Think I found a bug then
    On a reboot of the WAX510D set with 2.4G 11ax 20/40MHz it only runs in 20MHz mode but if I then change the channel width to 20MHz ok then back to 20/40MHz it runs in 40MHz mode.
    firmware V6.10(ABTF.10)
  • Zyxel_Bella
    Hi @PeterUK
    Because AP scans environment during the reboot process, it set to 20MHz if detect the rules mentioned above.
    You could also check if there's wireless signal using 20MHz via 2.4GHz by a wireless scanning tool like inSSIDer.
    Regards,
    Bella
    Not 100% sure thats right as changing 2.4G to 20MHz then back to 20/40MHz a wireless scanning tool shows 40MHz where as a reboot shows 20MHz surely it should show 40MHz even without clients that support 40MHz connected?
  • Zyxel_Bella
    Hi @PeterUK,
    AP won’t scan but only apply configurations if change the channel width setting.
    The channel width narrows to 20MHz when other functions trigger scan and detect legacy devices.
    Hope the mechanism description can make you more clarify.
    Thank you
    Regards,
    Bella
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    @PeterUK
    Which Wi-Fi scanning tool did you use? I tried your testing process with my WAX650S, but the channel width always stay in 20MHz whatever the channel width is configured at 20 or 20/40.
    So an idea just comes in my mind: Could the scanning tool read the 40 MHz capability inside AP's Beacon, and mis-print the channel width?
    Or, could the 20MHz only device be far away from your place, so the AP can't easily detect that device and switch to 20MHz immediately?
    The only moment I can see the 40 MHz channel width on GUI is, when I change the radio from a fixed 20/40 channel to a DCS 20/40 channel, in the short time AP will show 40 MHz, but soon recover to 20 MHz. (Guess it's because AP detects other 20MHz only devices)
    edited March 2021
    I used pingtools and net analyzer
    Here the thing why does 5G show the correct channel width but 2.4G does not?
  • Greenlight
    edited April 2021
    Is the APP "net analyzer" on the Android System? I can't find the related APP on Apple store that can check the channel width...
    BTW, I use My laptop with inSSIDer for above the test I mentioned above.
  • Zyxel_Bella
    Hi @PeterUK
    Only 2.4GHz has coexistence when detect legacy device but 5GHz will not.
    Regards,
    Bella
    yes
