SSL Inspection Pages SLOW
Hi @MPOster,
Can you please share some information with us;
3- Do you use default certificate for SSL inspection or you created new certificate for SSL inspection?
1- What's the name of the device and firmware version?
2- Does it always slows down the web page opening when SSL Inspection is enabled?
4- Can you please use the Zyxel device and query a website's category check if there's a latency during querying the websites? (Configuration > Security Service > Content Filter > Profile > URL to test)
Best regards.0 -
1-usgflex200
2-V4.62(ABUI.0) / 2021-01-19 11:22:24
3-I created a second one but am using the default one for now
CN=usg_flex_200_BCCF4FCF1B5CValidation Result=self-signed0 -
UPDATE:
Created a new certificate and installed on end-users. Same results -- slow internet loading on all SSL pages0 -
Hi @MPOster,
Can you share some information with us;
1- Does that slow opening impact some specific web pages or in general?
If so, can you please share the URL with us?
2-Does that issue occurs in specific time or randomly?
3- Did you set BWM for your network?
4- Can you check Configuration > Security Policy > Session Control > Default Session Per Host value? What's the value for Session Per Host?
Best regards.0 -
1-Seems after the page is cached, it opens fine the next time
2- As soon as SSL is activated in the Security Policy it slows down the page loads
3- NO it's off
4- 80000 -
I have the same problem with slow page opening. If Content Filter and SSL inspection are enabled, the pages are either very slow to open or not open at all. But turn off Content Filter and pages start to tear off again at normal speed.
Screenshot of Content Filter Profile:0
Is this the right key configuration?
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 231 Switch FAQ
- 201 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
