Reboot ATP800
Hello, since we put the console, the ATP800 has not restarted, although this message is always getting through the console.What can be?
src/central_freelist.cc:333] tcmalloc: allocation failed 65536
I attach the logsThank you.0 -
Hi @Pedroj,
In attached file I can't see src/central_freelist.cc:333] tcmalloc: allocation failed 65536 event.
How did you get this file?I think there are some misunderstanding.
Please connect your RS232 cable to ATP800 and follow the steps I mentioned before(9th entry of this topic).
Hi @Pedroj,
This bug has been solved in the current release.
Please download this version from the following link and upgrade to your device;
Best regards.
Hi OKI will update ATP800 with this version and I will tell you the result.Thank you.0
Hello, the ATP800 restarted today.
I attach the logs.
In them you see a Kernel panic.
It was not yet updated to version 462ABIQ0ITS-WK08-r98489.
What should I do? Could it be a Hardware problem?
[1496968.030041] Kernel panic - not syncing: Fatal exception in interrupt
[1496968.036582] panic_notify_sys Log Date: 1617901888
[1496968.041463] Firmware Version: 4.62 (ABIQ.0) | 2021-01-19 11:09:160 -
Hi @Pedroj,
Thank you for sharing information about this case.
We had fixed this symptom in the current release, please download and install the current release from the link below;
Hello, I will update the team and inform you of the result.Thanks.0
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 78 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
