Update ATP800 version ATP800 V4.60 (ABIQ.1) to 4.62 (ABIQ.0)
Pedroj
Pedroj Posts: 60  Ally Member
First Comment Sixth Anniversary
edited April 2021 in Security
Hi, I can't update ATP800 version
I have tried as normal from the firmware cloud and directly from local firmware and in the 2 partitions.
The result is the same, reboot and it seems that it is loading the new one
firmware, but after reboot it remains on V4.60.
I have tried it several times, what can I do?
Thank you.
    PeterUK Posts: 3,887  Guru Member
    You may have to backup your config reset then try updating to standby.
  • Zyxel_Can
    Zyxel_Can Posts: 342  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @Pedroj,
    Can you perform following steps;
    1-    Connect RS232 cable to ATP800.
    2-    Run Console software.
    3-    Perform local firmware upgrade.
    4-    Capture console log until reboot.
    After ATP800 boot up, can you share log output in this topic?
    Best regards.
  • Pedroj
    Hello, I have managed to update ATP800 in one of the partitions with the version
    V4.62_WK08 / 462ABIQ0ITS-WK08-r98489
    The problem now is that ATP800 restarts.
    After everything works correctly.
    What I can do??
  • Zyxel_Can
    Hi @Pedroj,
    Is current running partition’s firmware version is v4.62 WK08?
    If so, please connect RS232 cable to ATP800 and collect log as in the following video until next reboot and send me by private message?
    https://www.dropbox.com/s/ioxuliuh41tc5h6/collect_console.wmv?dl=0
  • Pedroj
    Hello, ATP800 is working with version v4.62 WK08
    I will put a PC to collect by console the next reboot.
    I keep you informed.
    Thanks.
