USG110 - problem check AV signatures
kyssling
kyssling Posts: 107  Ally Member
First Comment First Answer Friend Collector Sixth Anniversary
edited April 2021 in Security
from 29.3.2021 our USG 110 stop update AV Signatures. When i check manually : "AV signature download has failed. (failed) at Tue Apr 6 12:21:29 2021"
same manual check GeoIP database : "Geo-IP country database version 20210406 download has failed. (failed) at Tue Apr 6 12:28:58 2021".
IDP updates succesfully. Until 29.3.2021 updates running normal.
Anti-Virus Signature Service Activated Expiration : 2022-4-28
Latest FW V4.62(AAPH.0)ITS-WK08-r98489
Thanks for help ...
  • jonatan
    jonatan Posts: 199  Master Member
    I have the same error, I think they will soon solve the problem.
  • jonatan
    The AV signature update is working.It looks like there was a problem with the cloud base.
  • kyssling
    Today I can update AV+IDP signatures. GeoIP still get message "Geo-IP country database version 20210406 download has failed. (failed) at Wed Apr 7 11:33:34 2021" ...
  • itariant
    itariant Posts: 20  Freshman Member
    First Comment Seventh Anniversary
    Same problem on all ATP and USG, help!!!
  • Trust_IT
    Trust_IT Posts: 1
    We too have this problem on all our devices.
    This is bad since we have Geo-Blocks in place that block wrong IPs because the update is not working.
    ZyXEL must be aware of this. It would be nice if they would provide at least a "Yes we know" message here ...
  • jonatan
    The GeoIP database has been updated.
  • kyssling
    Yeah now is running update without problem... Any Zyxel reactions WHY is more than SEVEN days does not AV + GeoIP updates running normally ?
  • Zyxel_Can
    Zyxel_Can Posts: 342  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi All,
    Signature updates problem has been solved.
    It wasn’t working for short time because of the server maintenance.
    Sorry for inconvenience.
    Best regards.
