Reboot ATP800
Hello, since we put the console, the ATP800 has not restarted, although this message is always getting through the console.What can be?
src/central_freelist.cc:333] tcmalloc: allocation failed 65536
I attach the logsThank you.0 -
Hi @Pedroj,
In attached file I can't see src/central_freelist.cc:333] tcmalloc: allocation failed 65536 event.
How did you get this file?I think there are some misunderstanding.
Please connect your RS232 cable to ATP800 and follow the steps I mentioned before(9th entry of this topic).
Hi @Pedroj,
This bug has been solved in the current release.
Please download this version from the following link and upgrade to your device;
Best regards.
Hi OKI will update ATP800 with this version and I will tell you the result.Thank you.0
Hello, the ATP800 restarted today.
I attach the logs.
In them you see a Kernel panic.
It was not yet updated to version 462ABIQ0ITS-WK08-r98489.
What should I do? Could it be a Hardware problem?
[1496968.030041] Kernel panic - not syncing: Fatal exception in interrupt
[1496968.036582] panic_notify_sys Log Date: 1617901888
[1496968.041463] Firmware Version: 4.62 (ABIQ.0) | 2021-01-19 11:09:160 -
Hi @Pedroj,
Thank you for sharing information about this case.
We had fixed this symptom in the current release, please download and install the current release from the link below;
Hello, I will update the team and inform you of the result.Thanks.0
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
