Multy U (wsr30) issue to connect 2nd node
Kelly
Kelly Posts: 1 image  Freshman Member
edited November 2020 in Multy WiFi System
can someone advise, what may I do wrong?
i bought 3 Multy U (WSR30). Installing the primary device through Ethernet cable was smooth, and works fine.
I am trying to add a 2nd node to extend WiFi range. When going through the installation steps, additional Multy is found and connected through Bluetooth, but location checks fails all the time. Already tried in close distance (i.e. 2m), mid-distance (6-7m) and longer distance (10m with wall between); none found connection.
any tips?
thanks!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406
    image  Zyxel Employee
    Dear Sir,
    We have received your feedback from multy app, and we will contact you via email.
    Best regards,
    Jerry
  • militsky
    militsky Posts: 1 image  Freshman Member
    I have the same problem :(
    Please help!!
  • Zyxel_Jerry
    Dear Sir,
    Best regards,
    Jerry
  • Mollerup
    Mollerup Posts: 1 image  Freshman Member
    Same problem for me. Seems to be stuck on the location check. Please help.
  • Zyxel_Jerry
    Hi @Mollerup,
    Could you describe more details about your issue?
    1.How do you connect your Multy device in your environment?
    2.Which model of Multy device are you using?
    3.What is the firmware version of the Multy device?
    4.Could you provide us a video related to your issue?
    5.Please send us the feedback on the Multy APP.
