Switch Settings Clone Tool destinations greyed out.
Hi @grnerd,
Only if the source switch and the destination switch are same model(not same series) it should work. If you've checked the model and still not work on your site please contact local support. Will need some org. information to check the problem.
G'day, I have reply you on ticket channel, since you have bind this site to the template therefore you cannot clone other switch setting to this device.
Update to every one, this case has been resolved in ticket channel.If you put the site into the template then you cannot clone the switch setting to this site, since the template has it's own switch profile to follow.0
- 588 USG FLEX H Series
- 476 News and Release
