Switch Settings Clone Tool destinations greyed out.
grnerd
grnerd Posts: 8 image  Freshman Member
Third Anniversary
I am trying to clone the switch configuration from one switch to another, both the same model. I can select the source switch, but when I try to choose the destination switch, they are all greyed out. What am I doing wrong?
  • Zyxel_Albert
    Zyxel_Albert Posts: 36 image  Zyxel Employee
    First Answer First Comment Friend Collector Third Anniversary
    Hi @grnerd,
    Only if the source switch and the destination switch are same model(not same series) it should work. If you've checked the model and still not work on your site please contact local support. Will need some org. information to check the problem.
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    G'day, I have reply you on ticket channel, since you have bind this site to the template therefore you cannot clone other switch setting to this device.
  • Zyxel_Chris
    Update to every one, this case has been resolved in ticket channel.
    If you put the site into the template then you cannot clone the switch setting to this site, since the template has it's own switch profile to follow.
Nebula Tips & Tricks
