VLAN and Web Authentication on UAG 5100
Hi @Stuart,
Do you have “Lan2 to Device” this rule on Configuration > Security Policy > Policy control ?
If the security rule was delete, it is unable to redirect the web portal to vlan300(Lan2) user.
Yes I do. Here is the Policy.
Hi @Stuart,
Can you send me your configuration file via private message.
let me try it on lab device.
Regards,
Cooldia.
I have sent you the config in a message.
Hi @Stuart,
Please change the VLAN300 interface type from “general” to “Internal”, it is the reason why it unable to redirect the web authentication.
BTW, your device firmware version is V4.10, the latest firmware version is V4.18, I would suggest to upgrade the latest firmware version.
Here is the download link.
https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-01750&md=UAG5100
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
