VMG1312-B10D wake on lan?
Peter Tselios
I have the VMG1312-B10D as my home router. I definitely don't want to replace it with anything newer since it works more than fine for what I need.
However, I have a special need. Due to poor electricity network in my area, UPS is not able to keep my home server up and running for the whole power-out duration. Unfortunately, the MB/PSU combination is not working with the "Power On upon power restore" option.
So, I need a way to use the Wake On Lan. Does anyone have an idea how to schedule (crontab style) in the router a WOL signal to my PC?
Hello Peter,The information in section 8.7 of the user guide at ftp://ftp.zyxel.com/VMG1312-B10D/user_guide/VMG1312-B10D_V5.13_5.50.pdf might help you.If your server is getting its IP address automatically by DHCP, then you might need to enter the burnt in MAC address manually instead.I do not work for Zyxel and I have not tried this, but I hope that it works for you.I have also had power cuts recently, so have my Zyxel router (also VMG1312-B10D) on a battery backup since Friday.Kind regards,Tony0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
