SSL Inspection Pages SLOW
13
  • jonatan
    jonatan Posts: 198  Master Member
    The file sented in a personal message.
  • Zyxel_Can
    Zyxel_Can Posts: 342  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @jonatan,
    We are already debugging in your site. Please kindly wait for updates.
    Hi @Julien_ALM,
    Can you please share your startup-config.conf file with me by private message?
    I would like to test this case for you.
  • Motivio
    Motivio Posts: 21  Freshman Member
    Friend Collector First Anniversary
    Hi, I also have slow Website loading with SSL Inspection on my FLEX 100, running the lates firmware.
    Especially pictures on a website are taking very long to load, while you are visiting the site for the first time. Without SSL Inspection it's very fast.
    Key Mode is: ECDSA-RSA-1024
    Regards,
    JO
  • MPOster
    MPOster Posts: 15  Freshman Member
    If you attempt to visit a website like zillo.com you will have to wait as if it were dial-up. As of ONE MONTH Zyxel has not logged into my USG-200 even though I gave them full access to it. Here is the funny part --- one of the headquarter spots of Zyxel is literally 9 miles away from my location in Anaheim. The tech looking into this has given me absolutely no feedback.
  • MPOster
    Looks like this is certainly an issue with Zyxel and not our ISP's
  • Zyxel_Can
    Hi @Motivio,
    Can you share some information with us;
    1-    How long does it take to open a website with SSL inspection enabled and without SSL inspection?
    2-    Which website do you use for testing?
    3-    Can you try to update your signature?
    (Configuration > Security Service > SSL Inspection > Certificate Update)
    4-    Can you provide me remote access to a client in your network and admin account to your gateway by private message?
    Hi @MPOster,
              Do you mean USG200 or USG FLEX 200?
              What’s the firmware version of your device?
  • Motivio
    @Zyxel_Can
    I've tested with the following website:
    https://bildarchive.motivio.de/archive
    I run the Certificate Update manually. Even that it didn't change the version in the display, there was a change afterwards, when I cleaned up the "Exclude List" under SSL Inspection.
    Now it seams to be ok.
  • MPOster
    I hope this didn't go stale -- I literally just shut off the SSL because I am sick of hearing the complaints but I want to get this fixed. My prior set-up was a Fortigate which uses the same system settings and I didn't have any issues with that one .
  • Zyxel_Can
    Hi @MPOster,
    We apologize for your inconvenience.
    We have addressed this symptom and currently we are working on the improvement.
  • DG_1
    DG_1 Posts: 6
    Hello!
    Is there any progress on this topic?
