Basic Network Static IP address
businessuer
in Nebula
I understand that you can set the usable dhcp range in the switch.
Let put the usable dhcp range as 192.168.0.5 - 192.168.0.253
192.168.0.254 is gateway.
Does that mean I can set 192.168.0.1 - 192.168.0.4 as static ip and it can ping the gateway?
Hi @businessuer
For your question, yes, IP address of 192.168.0.1 - 192.168.0.4 are available for static used after setting your DHCP range on switch.
Adam
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 459 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
