NAS 326 problem
pakumaci
pakumaci Posts: 2 image  Freshman Member
My NAS 326 is beeping. The firmware is the latest.
  1. I took the hard drives out and put them back in and it still beeps.
  2. I reset the unit but it does not seem like it can be reset.
  3. I took the hard drives out and turned the unit on and it DOES NOT beep.
  4. I tried to recover the data by using the Sabrent docking station and the drive is not accessible. It seems like the information is gone and the drives are not formatted. As you can see by the pictures below disks do show up, but the disk that I took out of the NAS has no file system.
I really need to not lose that information.
Can someone help me out?
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    You forgot the attachment.
    Beeping can be a sign that a raid array is degraded. When you take out the disks, the beeping stops, as there is no array.
  • pakumaci
    thank you sir
